- เข้าร่วม
- 31 ส.ค. 2009
- ข้อความ
- 12
:coolly-0044:
<meta http-equiv="Content-Type" content="text/html; charset=utf-8"><meta name="ProgId" content="Word.Document"><meta name="Generator" content="Microsoft Word 11"><meta name="Originator" content="Microsoft Word 11"><link rel="File-List" href="file:///C:%5CDOCUME%7E1%5CMaster%5CLOCALS%7E1%5CTemp%5Cmsohtml1%5C01%5Cclip_filelist.xml"><!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <wunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:ApplyBreakingRules/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><style> <!-- /* Font Definitions */ @font-face {font-family:"Angsana New"; panose-1:2 2 6 3 5 4 5 2 3 4; mso-font-charset:0; mso-generic-font-family:roman; mso-font-pitch:variable; mso-font-signature:16777219 0 0 0 65537 0;} /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0cm; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; mso-bidi-font-size:14.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman"; mso-bidi-font-family:"Angsana New";} @page Section1 {size:612.0pt 792.0pt; margin:72.0pt 90.0pt 72.0pt 90.0pt; mso-header-margin:36.0pt; mso-footer-margin:36.0pt; mso-paper-source:0;} div.Section1 {page:Section1;} /* List Definitions */ @list l0 {mso-list-id:1775587357; mso-list-type:hybrid; mso-list-template-ids:307522472 -1041725532 67698713 67698715 67698703 67698713 67698715 67698703 67698713 67698715;} @list l0:level1 {mso-level-tab-stop:36.0pt; mso-level-number-position:left; text-indent:-18.0pt; mso-ansi-font-size:14.0pt;} ol {margin-bottom:0cm;} ul {margin-bottom:0cm;} --> </style><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:ตารางปกติ; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> [FONT="]มีปัญหาจะสอบถามครับ พี่ๆ ขอความรู้ด้วยครับ[/FONT]
<o> </o>
[FONT="]- ทีนี้ถ้าผมขับในเมืองต้องใช้ [/FONT]OD off [FONT="]ใช่ไหมครับ แบบว่ารถติด เดี๋ยวหยุดเดี๋ยววิ่ง หรือเวลาขึ้นเขาทางลาดงี้อะ ที่รถต้องใช้กำลังรอบมากๆ[/FONT]
[FONT="]- แต่ถ้าวิ่งทางตรงยาวๆ เร็วๆนี่ใช้ [/FONT]OD on[FONT="] ใช่มั้ยครับ[/FONT]
[FONT="]แต่... คำถามคือถ้าผมจะเลือกใช้ตัวใดตัวนึงไปตลอด โดยขี้เกียจกดเปลี่ยนไปมาจะใช้ตัวไหนดีครับ เลือกไม่ถูก กลัวเกียร์ + เครื่องพังครับ เห็นว่าถ้ายกเนี่ยหลายหมื่น [/FONT]
<o> </o>
<o> </o>
- [FONT="]เรื่องของเกียร์ โอเวอร์ไดร์ฟ หรือ [/FONT]OD [FONT="]รถเซฟิโร่ [/FONT]A32
<o> </o>
- [FONT="]เรื่องของการโหลดครับ รถเซฟิโร่ [/FONT]A32[FONT="] ผมกะว่าจะตัดหรือดัดสปริงเดิม และอัดน้ำมันกึ่งแก็ส ทั้งหน้าหลัง และใช้ไปอีกซัก 1 ปี และในระหว่างนั้นก้อเก็บตังค์ ซื้อโช๊คกับสปริงแต่งอะครับ ดีมั้ย พอดี ถามร้านแถวพระราม 2 ทั้งหมด มัน 2,200 รับประกัน 6 เดือน พี่ๆว่าโอเคมั้ย มีร้านอื่นแนะนำป่าวครับ แบบ ถูกและดี พอดี ผมงบน้อยอะ[/FONT] [FONT="] พอดี ไปติดแก็ส [/FONT]LPG [FONT="]มาแล้วครับ[/FONT]
- [FONT="]อีกเรื่องครับ ผมกำลัง งง กับลมยางครับ ตอนนี้ ใส่ขอบ 17 หน้ายาง 235 - 45 [/FONT]–[FONT="] 17 จะถามว่าเติมลมเท่าไรดี ไม่แข็ง ไม่นุ่มเกิน และถ้าเปลี่ยน จะเปลี่ยนเป็น 205 [/FONT]–[FONT="] 45 หรือ 215 -45 ดี และจะเติมลมเท่าไรครับถ้าจะประหยัดน้ำมัน:coolly-0033:<o></o][/FONT]
