[TBODY][TR style="mso-yfti-irow: 0; mso-yfti-firstrow: yes"][TD style="BORDER-RIGHT: black 1.5pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #f4f4f4; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #f4f4f4; WIDTH: 33.26%; PADDING-TOP: 0cm; BORDER-BOTTOM: black 1.5pt solid; BACKGROUND-COLOR: transparent" vAlign=top width="33%"]
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com
ffice
ffice" /><o
></o
[/TD][TD style="BORDER-RIGHT: #f4f4f4; PADDING-RIGHT: 5.4pt; BORDER-TOP: #f4f4f4; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #f4f4f4; WIDTH: 33.46%; PADDING-TOP: 0cm; BORDER-BOTTOM: black 1.5pt solid; BACKGROUND-COLOR: transparent" vAlign=top width="33%"]
VH45DE
<o
></o
[/TD][TD style="BORDER-RIGHT: #f4f4f4; PADDING-RIGHT: 5.4pt; BORDER-TOP: #f4f4f4; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #f4f4f4; WIDTH: 33.28%; PADDING-TOP: 0cm; BORDER-BOTTOM: black 1.5pt solid; BACKGROUND-COLOR: transparent" vAlign=top width="33%"]
1UZ-FE
<o
></o
[/TD][/TR][TR style="mso-yfti-irow: 1"][TD style="BORDER-RIGHT: black 1.5pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #f4f4f4; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #f4f4f4; WIDTH: 33.26%; PADDING-TOP: 0cm; BORDER-BOTTOM: #f4f4f4; BACKGROUND-COLOR: transparent" vAlign=top width="33%"]
Type
<o
></o
<o
></o
[/TD][TD style="BORDER-RIGHT: #f4f4f4; PADDING-RIGHT: 5.4pt; BORDER-TOP: #f4f4f4; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #f4f4f4; WIDTH: 33.46%; PADDING-TOP: 0cm; BORDER-BOTTOM: #f4f4f4; BACKGROUND-COLOR: transparent" vAlign=top width="33%"]
DOHC 32-Valve V8 with aluminum-alloy block and heads with molybdenum coated pistons
<o
></o
[/TD][TD style="BORDER-RIGHT: #f4f4f4; PADDING-RIGHT: 5.4pt; BORDER-TOP: #f4f4f4; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #f4f4f4; WIDTH: 33.28%; PADDING-TOP: 0cm; BORDER-BOTTOM: #f4f4f4; BACKGROUND-COLOR: transparent" vAlign=top width="33%"]
DOHC 32-Valve V8 with aluminum-alloy block and heads.
<o
></o
[/TD][/TR][TR style="mso-yfti-irow: 2"][TD style="BORDER-RIGHT: black 1.5pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #f4f4f4; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #f4f4f4; WIDTH: 33.26%; PADDING-TOP: 0cm; BORDER-BOTTOM: #f4f4f4; BACKGROUND-COLOR: transparent" vAlign=top width="33%"]
Displacement
<o
></o
4.5L.
<o
></o
4.0L
<o
></o
[/TD][/TR][TR style="mso-yfti-irow: 3"][TD style="BORDER-RIGHT: black 1.5pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #f4f4f4; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #f4f4f4; WIDTH: 33.26%; PADDING-TOP: 0cm; BORDER-BOTTOM: #f4f4f4; BACKGROUND-COLOR: transparent" vAlign=top width="33%"]
Horsepower
<o
></o
278 @ 6000rpm
<o
></o
250 @ 5600rpm (SC400)
<o
></o
[/TD][/TR][TR style="mso-yfti-irow: 4"][TD style="BORDER-RIGHT: black 1.5pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #f4f4f4; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #f4f4f4; WIDTH: 33.26%; PADDING-TOP: 0cm; BORDER-BOTTOM: #f4f4f4; BACKGROUND-COLOR: transparent" vAlign=top width="33%"]
Torque
<o
></o
292 @ 4000rpm.
<o
></o
260 @ 4400rpm (SC400)
<o
></o
[/TD][/TR][TR style="mso-yfti-irow: 5"][TD style="BORDER-RIGHT: black 1.5pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #f4f4f4; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #f4f4f4; WIDTH: 33.26%; PADDING-TOP: 0cm; BORDER-BOTTOM: #f4f4f4; BACKGROUND-COLOR: transparent" vAlign=top width="33%"]
Bore x Stroke
<o
></o
93 x 82.7mm
<o
></o
87.5 x 82.5mm
<o
></o
[/TD][/TR][TR style="mso-yfti-irow: 6"][TD style="BORDER-RIGHT: black 1.5pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #f4f4f4; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #f4f4f4; WIDTH: 33.26%; PADDING-TOP: 0cm; BORDER-BOTTOM: #f4f4f4; BACKGROUND-COLOR: transparent" vAlign=top width="33%"]
Main Bearing and Support
<o
></o
6 bolt main bearings (bigger) with cradle support.
<o
></o
6 bolt mains.
<o
></o
[/TD][/TR][TR style="mso-yfti-irow: 7"][TD style="BORDER-RIGHT: black 1.5pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #f4f4f4; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #f4f4f4; WIDTH: 33.26%; PADDING-TOP: 0cm; BORDER-BOTTOM: #f4f4f4; BACKGROUND-COLOR: transparent" vAlign=top width="33%"]
Crankshaft
<o
></o
90 degree forged steel.
<o
></o
Forged.
<o
></o
[/TD][/TR][TR style="mso-yfti-irow: 8"][TD style="BORDER-RIGHT: black 1.5pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #f4f4f4; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #f4f4f4; WIDTH: 33.26%; PADDING-TOP: 0cm; BORDER-BOTTOM: #f4f4f4; BACKGROUND-COLOR: transparent" vAlign=top width="33%"]
Connecting Rods
<o
></o
Steel. (Bigger cross section and diameters)
<o
></o
Cast.
<o
></o
[/TD][/TR][TR style="mso-yfti-irow: 9"][TD style="BORDER-RIGHT: black 1.5pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #f4f4f4; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #f4f4f4; WIDTH: 33.26%; PADDING-TOP: 0cm; BORDER-BOTTOM: #f4f4f4; BACKGROUND-COLOR: transparent" vAlign=top width="33%"]
Compression Ratio
<o
></o
10.2:1.
<o
></o
LS and SC400 – 10.0:1
<o
></o
[/TD][/TR][TR style="mso-yfti-irow: 10"][TD style="BORDER-RIGHT: black 1.5pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #f4f4f4; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #f4f4f4; WIDTH: 33.26%; PADDING-TOP: 0cm; BORDER-BOTTOM: #f4f4f4; BACKGROUND-COLOR: transparent" vAlign=top width="33%"]
Induction System
<o
></o
Sequential multi-point fuel injection.
<o
></o
<o
></o
[/TD][/TR][TR style="mso-yfti-irow: 11"][TD style="BORDER-RIGHT: black 1.5pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #f4f4f4; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #f4f4f4; WIDTH: 33.26%; PADDING-TOP: 0cm; BORDER-BOTTOM: #f4f4f4; BACKGROUND-COLOR: transparent" vAlign=top width="33%"]
Port and Manifold design
<o
></o
<o
></o
Long high flow and tuned length intake runners with central plenum.
<o
></o
Log type plenum manifold.
<o
></o
[/TD][/TR][TR style="mso-yfti-irow: 12"][TD style="BORDER-RIGHT: black 1.5pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #f4f4f4; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #f4f4f4; WIDTH: 33.26%; PADDING-TOP: 0cm; BORDER-BOTTOM: #f4f4f4; BACKGROUND-COLOR: transparent" vAlign=top width="33%"]
Throttle body
<o
></o
90mm
<o
></o
70mm
<o
></o
[/TD][/TR][TR style="mso-yfti-irow: 13"][TD style="BORDER-RIGHT: black 1.5pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #f4f4f4; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #f4f4f4; WIDTH: 33.26%; PADDING-TOP: 0cm; BORDER-BOTTOM: #f4f4f4; BACKGROUND-COLOR: transparent" vAlign=top width="33%"]
Valvetrain
<o
></o
DOHC 4-valves-per-cylinder with variable valve timing control. Timing chains.
<o
></o
DOHC 4-valves-per-cylinder.
Single timing belt. (less mechanical noise).
<o
></o
[/TD][/TR][TR style="mso-yfti-irow: 14"][TD style="BORDER-RIGHT: black 1.5pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #f4f4f4; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #f4f4f4; WIDTH: 33.26%; PADDING-TOP: 0cm; BORDER-BOTTOM: #f4f4f4; BACKGROUND-COLOR: transparent" vAlign=top width="33%"]
Ignition
<o
></o
<o
></o
Direct ignition system with platinium tipped plugs (individual coil per cylinder).
<o
></o
Distributor cap on the end of each intake camshaft.
<o
></o
[/TD][/TR][TR style="mso-yfti-irow: 15"][TD style="BORDER-RIGHT: black 1.5pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #f4f4f4; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #f4f4f4; WIDTH: 33.26%; PADDING-TOP: 0cm; BORDER-BOTTOM: #f4f4f4; BACKGROUND-COLOR: transparent" vAlign=top width="33%"]
Maximum engine speed (std)
<o
></o
6900rpm
<o
></o
6600rpm
<o
></o
[/TD][/TR][TR style="mso-yfti-irow: 16"][TD style="BORDER-RIGHT: black 1.5pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #f4f4f4; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #f4f4f4; WIDTH: 33.26%; PADDING-TOP: 0cm; BORDER-BOTTOM: #f4f4f4; BACKGROUND-COLOR: transparent" vAlign=top width="33%"]
Weight (engine plus ancillaries)
<o
></o
231kg
<o
></o
213kg
<o
></o
[/TD][/TR][TR style="mso-yfti-irow: 17"][TD style="BORDER-RIGHT: black 1.5pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #f4f4f4; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #f4f4f4; WIDTH: 33.26%; PADDING-TOP: 0cm; BORDER-BOTTOM: #f4f4f4; BACKGROUND-COLOR: transparent" vAlign=top width="33%"]
Dimensions
<o
></o
see left image
<o
></o
see left image
<o
></o
[/TD][/TR][TR style="mso-yfti-irow: 18; mso-yfti-lastrow: yes"][TD style="BORDER-RIGHT: black 1.5pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #f4f4f4; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #f4f4f4; WIDTH: 33.26%; PADDING-TOP: 0cm; BORDER-BOTTOM: #f4f4f4; BACKGROUND-COLOR: transparent" vAlign=top width="33%"]
Other
<o
></o
No adaptor kits currently available, however Nissan Patrol transfer case can be easily added to Infiniti gearbox <o
></o
Wide range of adaptor kits available <o
></o
[/TD][/TR][/TBODY]
