วิธีการใส่ลูกเต็ดซิ่ง เผื่อว่าใครจะสนใจครับ
  • ผู้เริ่มหัวข้อ ผู้เริ่มหัวข้อ A31021
A31021
22 พฤษภาคม 2007
[TBODY][TR height="100%" UNSELECTABLE="on" width="100%"][TD id=HB_Focus_Element vAlign=top width="100%" background="" height=250 UNSELECTABLE="off">
ไปเจอมาตาม link เผื่อมีใครสนใจจะลองรื้อเอง เป็นภาษาอังกฤษนะครับ แต่ก็พอจะเข้าใจได้ตามรูป http://forums.nicoclub.com/zerothread?id=217546&postid=2284747 Tools Needed
-Torque Wrench
-Electric/Air ImpactGun/Wrench
-Hammer
-Flathead
-Common size sockets and wrenches of various sizes
-Medium sized tap or large screw driver (my large pry bar did the trick)
-Brake Cleaner
-Scotchbrite
-Gasket Scraper
-Gear Marker
-ThreadLocker
-Drain pan
-Cheap thick gear oil with Motorcraft Additive Friction Modifier (Provided by FRSport.com)
-Block of wood
-1 or more friends
Step 1
Prep the area with a long, clean, working table, with a clean table cover (large sheet of heavy duty plastic will do).
-Jack up the Car
-Drain the differential fluid
-Once drained, place the transmission in gear and make sure e-brake is engaged. Unbolt driveshaft from differential. 4 bolts 12 or 14mm.
-Remove sway bar and lower your exhaust by removing it off the hanger. (Makes your life easier.)
-There are 2 17mm bolts holding the differential to the underside of the car. Loosen those two bolts, do not fully remove.
-Remove (4) 17mm bolts from back of differential.
-Before lowering the differential try to move the axles out of the way.
-Now when you/'/re ready take off the two 17mm bolts you had loosened and carefully lower the differential with the jack.
Step 2
Bring your differential over to your working station.
-Remove differential cover by unbolting with a 14mm ratchet in a criss-cross pattern.
What it looks like once it/'/s revealed.
-Mark the axle shaft accordingly which side it came from.
-Now carefully, bang off the axle shaft with a hammer without hitting the ring gear.
-Once the axle shaft is off, place them on the clean table. You could put them on the side accordingly to where they came off on the table.
Step 3
-Remove bearing cap bolts and bearing cap. Have a friend hold down the differential.
-Keep the bearing caps accordingly to which side and direction it came from.
Step 4
-You can use a wrench or a pry bar, to remove the open differential. I used the wrench and hit one end with a hammer to pry it out.
What it looks like once it/'/s removed.
-Be very careful, once the differential is out. Keep the Spacers according to its exact order and side.
Step 5
-With a hammer and flathead, chisel away the old gasket. I recommend to use Gasket Scraper, to avoid any seal failure.
-Do the same on the differential cover. Use Scotchbrite to remove the remaining gasket on the cover and differential.
Step 6
-Spray the inside of the pumpkin with Brake Cleaner and clean the inside the pumpkin, and on the differential cover. Dirt is your worst enemy
แจ๋มจิงๆๆๆๆๆๆๆ
โอ้โฮ
แล้วเรา จะไปซื้อ อะไหร่ แบบมันที่ไหน กัน ละหน๋ะ
